Portable Diesel Generators - Safer On Boats ?
Hi guys. Am considering adding a portable generator on my 330 to replace the Kohler 7.3. Having read up on the pitfalls associated with a petrol powered portable generator on a boat , am now having a serious look at some small portable diesel powered generators (between 5 to 7 kva).
As I understand the issue with petrol powered portable gensets
- CO2 emission,
- if installed in engine compartment , the fuel tank vents to air,
- exhaust routing,
- cooling issues,
- ignition safety.
Would these be different with a diesel setup ?
Thanks.
- CO2 emission,
- exhaust routing,
- cooling issues,
- ignition safety.
Thanks.
I have a 6k propane generator, lasts about 4 hours on a 20lb tank, but since propane is for ever I plan on getting a large tank installed and feeding my dryer, generator and stove from the one tank.
I'm happy with mine. how ever it's important to remember that power from propane will cost you double the cost of power from diesel fuel as propane has a lot less "energy" when compared to diesel.
