Water flow issue or not?
davidbrooks
Member Posts: 1,418 ✭✭✭✭
Trying to see if i am becoming a hypochondriac or not. So i have a 2003 342 with Horizon 350 MPI. Closed water cooled. Port engine is about as stable as you could ask for. Love that engine, never causes me any worries. Starboard engine on the other hand is my problem child. So i replaced impellers on both engines at the beginning of the season. Port engine struggled to prime but eventually did. Now when i go out there are two things happening. That engine feels like it is in guardian mode as i don't get any additional umph from 1/2 throttle to full throttle and temps seem to be all over the place on the gauges. Remember i replaced all the guages this winter also. Rewired the wiring harness....hey what could of gone wrong right? At idle the guages show the temps going up to 200 and then coming down to 175 while cruising. If i put a Rinda tool on the engine there are no codes saved, 100% power. I can also pull the blue plug at the top of the engine by the coolant tank and get water spouting out.
My thought was that it was partially obstructed somewhere and that while on idle i wasn't getting enough water flow. How do i measure this though. I don't see a water pressure reading on the ECM. So other than taking everything back apart again...where would you start. I am already pretty unhappy with the consistency of the gauges and thinking of replacing the whole dash again. This time going digital and Smarttech. However i need to replenish the piggy bank first. In the meanwhile i really don't want to blow an engine.
Recommendations?
Recommendations?
My first thought on wonky gauge readings is bad ground. If your engine is in guardian mode I'd expect it to show up on Rinda as well.
Curious to see what our resident pros offer on the subject.
I Replaced the impeller and the old one didn't look bad. Had good water flow to the transmission cooler and no obstructions so next step is to do a @Wildboating
and start pulling off hoses. Hopefully i don't have to pull the risers. As far as an order to follow... any suggestions?
First off, let me make sure we are talking the same stuff here. You have a 03 342, 350 Mag MPI MCM motor with the ECM 555 on your port manifold correct?
If so which Rinda do you own, a techmate or the Diacom?
Water pressure will read as Sea Pump Pressure, it reports back as psi. You should be seeing around .9-1psi at idle speeds and upwards of 11 psi at wot.
Are you experiencing any alarms? I am almost positive you would be setting an alarm way before 200 degrees. Your thermostat is likely 160 degrees, you should not be seeing temps of 175 even at speeds unless we have a flow issue which again i would suspect we would be receiving an alarm. Let me know on these and i will help you dig deeper.
