Just finished one of the most unglamorous jobs of boat ownership
davidbrooks
Member Posts: 1,418 ✭✭✭✭
I was struggling with a smell that i just couldn't pinpoint. It was mostly noticeable in the cabin but i could also smell it when i was taking off the cover at the helm. So i started cleaning....and cleaning. I pulled out every possible access. Cleaned, sprayed and cleaned some more. Started with the anchor locker and worked my way back. Then i realized i was going to have to remove the holding tank to finish the job. I really hope i never have to do that again.
As others have said you have to disassemble the aft berthing area, remove the cabinets and it is then right there. The one thing i will tell you is that even if you hit the pumpout station you will not and i repeat will not get it all. We ran the pump 3 times. The first two i think it just cut off on a timer. The last one we stopped it. When i pulled out the tank I taped off the openings with duct tape and also taped off the hoses. That smell came through anyway. I debated throwing away the tank vs cleaning it and if i could of found a direct replacement i probably would have. The closest one i could find to the size and shape was going to take 6 weeks and i couldn't verify the fittings were correct.
So i started cleaning. Degreaser, bleach, it doesn't matter. Still smells. At that point i decided to just try and seal it in. So i found every can of enamel spray paint i could get my hands on in my work shop and just started spraying. It really did end up helping a ton. The area all around the tank itself was disgusting. I think the vent hose fitting was loose and as it got a little too full it would leak out. So that got tightened and lesson learned. Pump out more often.
Put it back in and reassembled the whole thing. Then i dumped a gallon of blue RV holding tank liquid into the toilet and flushed it with some clean water. My thought was to give it a good base first. I have to tell you it was disgusting but in the end made a big difference. There is nothing worse that having that smell that you cant get rid of.
The other thing i discovered was that if you reach into the mid bilge area and then reach forward as far as your arm can go there is an area that water can get trapped in. Only about an inch or two but it can sit there and get stagnant. The only way to get it out is to shop vac it or have a bunch of towels. If i ever rip up the floor i will redo that so it all drains. Now i know to check it.
Did you happen to take pictures of the aft all taken apart? Would be interesting to see how it all looked.
The best thing out this whole exercise was i dumped out the contents at the corner of my property and the wind was blowing it over to my neighbor. He started it.
most unglamorous jobs of boat ownership, I feel your smell, It's a horrible job.
