Adding a second shore power
Britinusa
Member Posts: 306 ✭✭
Hi all, I’m adding a second shore power receptacle, it will be on the outside of the boat to make it easier to connect and move the cord from inside the rear seating area where it is now.
question is, what type of electrical cable do I need, does it need to be marine rated?
Routing the wire was a PITA. I went through the spot where the water lines and the factory shore power went, behind the water heater.
