Starboard marine lumber - how to finish cut edges?
LaRea
Member, Moderator Posts: 7,934 mod
Can anybody suggest a good way to finish cut edges on a piece of Starboard marine lumber?
I try to avoid having visible edges, but that's not always possible. What I usually do is round the edge with a router, and sand it smooth. But the rest of the board has a pebble finish, so the sanded edge looks different. No matter how smooth I sand it, it's never quite right. I want a way to reproduce that pebble finish on the cut edges.
Maybe some sort of hand-held knurling tool with a diamond pattern ... anybody ever tried it?
I had the same issue and I saw a video the other day (link was either on this forum or somewhere else during my search) in which the guy heated up the seaboard surface with a propane plumbers torch to just barely the melting point, then quickly dabbed the surface with sandpaper -- the grit matching the type of pebble effect he wanted to mimic -- and the sandpaper was in effect his patterning tool. The key was to dab, not pull or scrape. The dabbing created the nice pebble pattern. Just need to find a grit closest to the surface you have.
Looked good in the video, I just haven't had time try it.
You may want to experiment on a scrap first! LOL
https://www.youtube.com/watch?time_continue=3&v=n8MdVNAGSE8
The pertinent section (using the sandpaper to pebble the plastic) starts around the 4:30 mark. He's doing it on thinner piece of HDPE, repairing a jet boat, but Seaboard is also HDPE, so I think the same technique would work.
@TonyG13 thanks! I tried this method, and it works fine on Starboard.
I used a router to make a 1/4" radius corner, then sanded it with 100-grit paper on an orbital sander. Then I briefly heated the surface with a torch, and dabbed it with clean 100-grit sandpaper to produce a pebble finish.
What I got is a nice matte finish that hides the toolmarks and basically just disappears. If you get up close and look for imperfections, yeah ... it's not a 100% perfect match. But if you see it from typical distances, nobody's going to notice. And it looks way better than tool marks or a sanded finish.
One thing to note: the heat can make the original finish get slightly shiny, so you have to be careful with the torch.
Actually, it's hard to get a photo that really shows the finish. The second photo doesn't quite capture it.
