Towing 270 with surge brakes....question
 04FV270riverrat
                    Member Posts: 268 ✭✭✭
04FV270riverrat
                    So my trailer has surge brakes instead of electric or electric/hydraulic. Every time I stop, I can feel/hear the hitch compressing and when I take off from a stop, I can feel it pull out until it catches and then a big jerk before the trailer starts rolling. Anyone else’s do this? I don’t feel like it’s good long term and I eventually want to convert the trailer to electric/hydraulic brakes.
EoH can be activated independently In a sudden stop, provided you keep your wits about you: you can reach down and activate the trailer brakes before your tow vehicle has even begun to slow. On a downhill, off camber turn (which is the high risk maneuver for surge brakes - the force required to engage trailer braking is usually equal or higher than the force required to fishtail the tow vehicle) you can keep control and even use the trailer braking to help steer the tow vehicle. The EoH brakes can keep the boat from vacuuming in closer to an 18 wheeler (I-95 and I-26 around here are always under construction), and limit/stop trailer sway (not normally an issue with boats, but I've seen it happen to a huge boat on I-95 after swerving to avoid an accident.
EoH isn't for everyone, I'm sure, but I'm pretty sure towing 12500lbs with a 6500lb tow vehicle, EoH will give me an advantage.
