Water Pump
jdcstlbry
Member Posts: 21 ✭✭
I have a 2018 370EX and the water pump is the loudest that I have ever heard. Other boaters have even asked us about it during stays at various marinas. When water is turned on, when the ice maker is working, it makes a loud high pitched noise. I have thought about replacing the pump, modifying the install. Any suggestions?
If it's a high-pitched sound, I'd suspect a problem with the pump. A normal pump that's mounted incorrectly can be noisy, but it will usually be low-frequency noise.
