Water Pump
 jdcstlbry
                    Member Posts: 21 ✭✭
jdcstlbry
                    Member Posts: 21 ✭✭
                    I have a 2018 370EX and the water pump is the loudest that I have ever heard.  Other boaters have even asked us about it during stays at various marinas.  When water is turned on, when the ice maker is working, it makes a loud high pitched noise.  I have thought about replacing the pump, modifying the install.  Any suggestions?
If it's a high-pitched sound, I'd suspect a problem with the pump. A normal pump that's mounted incorrectly can be noisy, but it will usually be low-frequency noise.
