Lenco Autoglide and Merc Active Trim
When we demo'd Kim's 370 at the Miami show last year, it had the auto glide and the Merc active trim. It was nice to not have to touch the tabs or the trim (unless you wanted to manually). Neither are an expensive upgrade. Both seem to be plug and play. Has anyone upgraded to either one and was the install pretty simple? From what I read, the Lenco is as simple as changing out the black box and controller at the helm. Was just curious if it's worth it.
  • TonyG13TonyG13 Member Posts: 1,409 ✭✭✭✭
    As you know, while I didn't install it, it did come with our boat -- and it is a great addition! It's pretty sweet when you throttle up and a few seconds later the boat just magically levels off to the optimal angle for that given RPM and speed. Hopefully someone has had install experience and can give you some better guidance in that department.
