Yes-- fan is running as well-- when you look at the top in the back-- for the life of me I can't figure out how to recharge, or even if it should be-- will check actual make and do some additional research-- all seems working, just not cooling.
It is probably a Dometic/Waeco fridge. I don't believe they can be charged. If it needs charged, there is more than likely a pin hole somewhere. If that is the case, the charge won't last long. Did anyone try to defrost the unit recently?
These small units dont come with charging ports. You will have to install a self piercing schrader valve to fit the suction line. They dont take much Freon and its crucial to add the correct amount. Should be r134a
If you can't get the size then you would cut the suction line and solder one in. You really need a lot of knowledge here .Pull it out and take to an appliance repair shop. That will save alot
