Gimbal Bearing Grease Fitting
Does the Alpha 1 Gen 2 have a grease fitting or is it sealed? I cannot locate it and a search on line is not helping. The only thing I see is a little brass plug of some type. see photo. Also are the top and bottom gimbal ring pins a service item. No grease points I can see there either.
no
it should have a Zirk fitting
gen 2
difference is no u joint
or trim pivot zerks
vs gen 1
