How do get access to my fuel tanks in my 310
My fuel gauge on my starboard tank hasn’t worked since I bought the boat. When you turn the key the gauge will make the slightest movement so I’m guessing it’s the sending unit. I don’t know how to get access to the take to change it out. All diagrams I’ve seen on my boat show my tanks being in the engine compartment right where my fresh water tank and hold tank is. The best I can guess the tank is under the driver seat just not sure how to get to it. Any help ?
@cory143 - if you replace, go the better quality and higher priced vertical type, not the arm/float type. I had issues with mine and these are much better, no chance of getting hung up in the tank and easier to drop in versus maneuvering the arm around.
Next time I lift the hatch I’ll look more to see the top of the tank and where the sender is.
