Burning oil
2003 350 MAG - 380 hours
This engine has never burned a drop of oil, and then mid season, it started using a fair amount. I tracked it, and in the last 9 hours its burned .5 quart.
Today I warmed the engine up and did a compression check.
Results:
1- 158
2- 161
3- 150
4- 155
5- 154
6- 148
7- 151
8- 153
6 is a little low, but i dont see anything too alarming. Are valve seals a common issue in the 350 MAG?  Could also be the PCV, and i was going to change it but never got to it. I was going to do a leak down, but I’d have to remove the back seat to do it, so i didn't do it. I’m mainly just curious if people have had issues with valve seals. Also, all the plugs looked fantastic.  Any other ideas or common issues?
