Cable coax
When I got my boat the previous owner had the cable line running in through the window. When I look in the TV box there are 2 coax cables coming in through the wall. When I hook up to the dock cable neither give signal. Do these tend to go bad?
The black I'd suggest goes to another place for another TV, especially with a splitter there, you normally split the outgoing after the amp. Look for another coax inside why they may have stuck a TV.
Do you actually have a connection point outside near the power connector? If not you can install one, I did on ours.
If I remember correctly, Rinker uses the splitter in the reverse configuration, they take two inputs and combine it into one. Then that goes into the amplifier and the amplifier goes to the TV. Redo your connections ... you can buy some much better termination ends for not that expensive.
If you can cut out the splitter it will help, so if you don't need the antenna or the shore power connection (pick one), then cut out the one you don't need and use a coax to coax connector to go continuous to the amplifier. It works.
