Burning oil
2003 350 MAG - 380 hours
This engine has never burned a drop of oil, and then mid season, it started using a fair amount. I tracked it, and in the last 9 hours its burned .5 quart.
Today I warmed the engine up and did a compression check.
Results:
1- 158
2- 161
3- 150
4- 155
5- 154
6- 148
7- 151
8- 153
6 is a little low, but i dont see anything too alarming. Are valve seals a common issue in the 350 MAG? Could also be the PCV, and i was going to change it but never got to it. I was going to do a leak down, but I’d have to remove the back seat to do it, so i didn't do it. I’m mainly just curious if people have had issues with valve seals. Also, all the plugs looked fantastic. Any other ideas or common issues?
Results:
1- 158
2- 161
3- 150
4- 155
5- 154
6- 148
7- 151
8- 153
I was leaning towards valve seals too, but the more I think about it, it’s highly unlikely that multiple seals started leaking at the same time, meaning all the oil would be going out one cylinder and that would show up on the plug. I’m thinking it may actually be a crankcase venting issue and it’s being distributed enough that it doesn’t show up on the plugs because it’s a small amount going out all of them.
lets day when 30 weight is ran
Yes, one cylinder was low on the test. It wasn't crazy low, but you could see it was the oddball when comparing to other cylinders.
