Bravo 3 drive noise in upper end
I had a mysterious mechanical sound in my '04 Bravo 3 Merc drive so I pulled the drive last month and replaced the 9y/o Gimbel bearing. The gimbel bearing had one small spot when it was turned by hand that would seem to be a bit rough so I thought that'd do it, but it didn't. The U-joints were fine and we checked the alignment. While the tool didn't turn with two fingers for an ideal alignment it seemed fairly easy and not worth disturbing the motor mounts. There's no debris or water in the drive oil at the drain plug.
I ran the boat a few hours and it needed 2oz of drive oil but I figured it was just purging air/leakage in the line from removing the drive. Now the noise is persisting and sounds even more pronounced, especially in the top end of the drive. It's definitely a mechanical/gear sound in neutral or drive that I'm starting to feel queezy about the cost and whether I'm being over protective/paranoid or is it standard drive noise on a B3.
Any insight from those who've noticed OD gear noise when flushing a Bravo 3 drive on the hard?
Thanks, Mike
Thanks, Mike
Drain plug sample is free of debris and water but I'll check again tonight.
I've sent an email to the guys at All American Drives so we'll see if they have anything.
No debris is good. I know spinning mine the upper is quiet so noise is not a good sign.
The Blue Death does have a nice ring to it
when there is wear enough to alter the contact, gears will howl and/or whine.. that speaks of evil things taking place in your rig... but, I mentioned oil because it will also cause a howl/whine if it's not getting in between the contact surfaces (yet)... thicker oil can cause this, but it generally loses viscosity as it warms, where as thinner oil will maintain viscosity better, but maybe be too thin on the top end..
is there any possibility you bumped that thing good enough to alter a shims position? they will hold fine as can be whilst under pressure, but will often dance when the input shaft (pinion) is moved laterally.. and it only takes a little bit of wallow to unseat a shim.
another thing, though, is that (my observation) parts aren't made to be the quality they have been in the past.. that 9yo gimbel bearing is likely better quality than the new one... same w/ u joints.. there is a chance you replaced a heavily worn part(s), with a product that is out of balance..
My local mechanic said if there's no metal on the drain plug and the oil looks good that I'm just being OCD. Normal noise in the drive is pretty typical. I may trailer it down and have him listen to mine running on a set of muffs.
I'm open to other insight since I just pulled this thing off last month. I'd just hate to lay out that much cash and effort if there's something I'm missing. Wish I had somebody down here I could use with an ear for this stuff. The upside is similar to my recent seawater pump trial, I can get it off pretty easily now.....and I still have my shop for a few more months. And of course it comes on the heels of a $5000 paycut at work 2wks ago. #:-S Cmas will be unique if this little surprise from the Grinch of gear sets turns out poorly.
Thanks, Mike
There is no way gears are wearing without leaving behind evidence...
Small, almost paste debris is certainly wear... It just may be time for them.. chunks that you can pick up between fingernails? Ruh Roh.. something is amiss.. I'm hoping you're out of alignment due to a slipped shim, which can be corrected.. and you may be able to do it yourself- it just takes ridiculous patience to do it.. take out, observe pattern, adjust, reinstall, remove, observe pattern, adjust, reinstall, remove, observe pattern, adjust, reinstall, remove, observe pattern......... Grrr..... Beer is not an option while doing R&P work....
Re-doing a B-III on your own is a danger game. There are all kinds of special tools, slider parts that can be rarely saved (any scratches/galling ruin them)...I watched mine being taken apart, just a can of worms if you are not trained to do it. That from someone who likes to take things apart..and put back together
Al made mention about this on another thread too...use merc certified people.
At least with All American you get a 2 year warranty. Ask about using the neosynthetic oil he recommends...
Tonight I pulled the bottom magnetic drain plug looking for metal debris or water and it was completely free of anything foreign. I then pulled the top magnetic vent plug and it was also clean. My neighbor with 30yrs experience as a Mercruiser mech for a major marina in town thinks I'm hearing normal gear lash/interaction. He said if there's no debris on the plugs, it shifts fine, and no grinding when I spin the props with the motor off then it's most likely just in my head.
Soooo....Maybe it's just me being at a sensitive spot for big bills and just OCD paranoid with my $6000 drive. I guess I'm going to run it and keep an ear/eye on it to see if it gets worse or pukes.
Wish me luck and in the mean time I'll go see a therapist..... or start saving for a replacement drive
Taking your advice, I'll be seeing a local therapist who specializes in calming frayed nerves called Captain Morgan with his two assistants, a splash of coke and a twist of lime......
What do you mean you could move the props 3/8"? When in gear? separate from each other? 3/8" doesn't strike me as much slop.
What was your eventual solution and approx cost per drive?
omg where's the Captn Morgan.....
Thanks for adding your painful details. I hope mine is merely in my head but that is almost exactly how old and how many hours I have. No debris in the oil at this point and since we trailer I'd know immediately if it was leaking. Keeping my fingers crossed.
Interesting tool too. Thanks, Mike
