Replacement engine for 2001 Captiva 272 with 454 Mercury engine
My engine lost pressure in one of the cylinders so I have a decision to make, repair this OEM engine or replace it. What is the largest HP engine that can fit inside the engine compartment or the best economic one that is lighter but around 300_350 HP? I don't know how to size one or where to begin looking for an engine replacement. Any advice?
Best Answers
Cableguy Greg Member Posts: 5,069 ✭✭✭✭✭
Welcome aboard!!!Since you already have a big block, I would think that the boat would be able to fit another big block. If it was me, I would try to repair the existing engine first. Pull the heads and see what is going on. Worst case, get a long block and swap all of the other parts over from the old engine.2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes" (Sold)
Go Steelers!!! -
nascarnuts27
Member Posts: 9 ✭
I purchased a 282 Captiva w/8.1 Volvo Penta knowing the engine was frozen as a mechanics special. I have 2 full service auto repair shops so even if we had to pull the engine and put in a reman I would come out ok $$ wise doing all the labor myself with some help from my mechanics. For 3 weeks we worked off/on trying to unfreeze the motor with no luck plus it had a spark plug broken off flush with the block. Pulled it out with my son-in-law forklift and got a cylinder head off only to discover it was trashed actually grit inside the cylinders due to exhaust manifolds/risers that had not been flushed out and were rusted so bad the engine sucked crap back in the cylinders. Yes is was a salt water boat.....I had already priced a reman from Tri State Engines at $4800 (long block) and was about ready to order it when I found a local engine rebuild shop that rebuilds these engines (8.1 GM) for a nationally know rental and does them weekly. They quoted me $2600-$3000 so I went with them. Was supposed to be 3 weeks but ended up taking almost 3 months! They determined my old engine was so bad they didn't even want fool with it. So they started with another block (they have them in stock), bored it .030, and rebuilt it with stock components. I considered putting it high performance (after research determined that 5-8 extra MPH and increased fuel consumption wasn't worth it) with more compression/bigger cam/ etc but decided to just go stock despite the extra parts involved they still kept me at $3000. Finally the engine is in and it sounds great still having some teething problems getting it to idle right and take throttle properly but mechanically the engine is sound. I'll post when I get it broke in how it does. The GPS is stuck at 49.3 max speed from previous owner so I hope it will do 50.
Edit: Oh, and welcome to the forum, just noticed it was your first post!
This about $3050, without shipping. if you can pull the other one out and bolt on your parts, then reinstall. If you have the ability or tools to do it your self.
Crate Engine, Marine, Long Block, Assembled, External Balance, Cast Iron Heads, Chevy, 454, Each
(2)
Part Number: HME-DM25 More Detail...
For a bravo application they need to be nerfed a bit but the race guys are pumping 700 plus hp reliably off shore for thousands of hours.
They weigh in at about 800 lbs fullly dressed. Many are ditching turbos for blowers/super chargers or adding super chargers with turbos for race applications.
The adapter plate from chevy turns the back of them into a BBC.
The best years to use are about 2006 to 2007.5 due to ease of tuning/adapting/ upgraded injector design and there are already USA based companies that will make your ecu stand alone and custom tuned for your marine/hotrod applications.
The price for the conversion is much less depending on what work you can do yourself.
Also, BBC engine mounts can be modded to fit the duramax.
The military is already utilizing these motors in marine applications. The boats are set up with two power levels, much like a fancy sports car. With the flip of a switch they go from 450 hp to 700 plus. Slow patrol and all out for battle.
