Port windows seal
I want to seal all of my port windows this Spring. People on here have said they have done it from the outside. Now I know it's not the same as removing the window and doing it, but I'm looking for an easier way out and hopefully solve the water issue's I've had in past summers.
Any thoughts from those that have done it? Details would be appreciated.
IMO the only sure way is to pull the whole assy and caulk correctly at assembly. Just my .02.
@Skennelly - if yours is thinning there, it may fix it for you without taking it all apart. You could also look on the outer part where it meets the fiberglass to see how that caulking looks.
