How do I get the trim tab off?
rasburyrasbury Member Posts: 8,740 ✭✭✭✭✭
You know I had been wondering this for some time as I have no idea of how the wires are routed/access to them in the beige....and now I have to figure it out to get one off. The large "step" areas whee the waste and water tanks are....they have to run through there somewhere/how......is there access? do I need to pull something through to be able to get it back together???
Best Answers
    Answer ✓
    well that makes good sense...I just don't recall seeing them run down from there when I had the motor out....I will have to get back in there and look...since they are mounted at almost the bottom of the boat, you have the two "ledges" on either side of the motor where the tanks are, batteries etc....aren't the wires coming thru the transom lower than those "ledges"?
    Answer ✓
    sweet- I have looked on line everywhere and don't see that there is any way to order parts for them...they are a little pricey! Motor runs so assume a gear has stripped...
