Stress cracks sitting in storage
So the boating headaches begin and I still have a few months before getting wet.
Walking around my 342 this morning Ive noticed cracks developing on the port side.
I know for a fact that these were not there in the fall and Im also pretty confident they were not there last month. My vinyl was installed last year and long story short wasn't the greatest install and have a lot of bubbles so been keeping a very close eye and would have noticed these cracks almost immediately. Usually go there once a week and today is the first time seeing them.
My questions are this, what would cause cracks just sitting all winter? Is this something that would compromise the structural integrity? Would a survey be able to tell me the exact root cause?
It may not have happened "when" it was pulled, but still caused by the stress of the pull-out. I agree with what MT said & I too have seen the V-groove done with success by something that knows what they are doing.
Was also curious if the way the boat is sitting all winter could come into play? My marina uses foam blocks, not saying its not the proper way but I called 3 manufacturers and they did not recommend their product for my size boat. I also noticed the boat "wobbles" on the blocks when you're on it which to me seems like a lot of weight to be moving around.
I have gelcoat cracks on my boat too. They don't propagate.
could be in properly blocked
Could be stress cracks caused by something inside the boat moving around
like the galley etc
not sure that would cause the cracks though, as I've said a lot of that is because of the lifting with the straps.
Corrected the jackstand number.
like I said sling or something pushing or
moving inside the boat causing the stress
What side of of the boat are they on?
It's more than just the 342s. I've seen it across the larger range of cruisers, specifically the ones at our marina large enough to use the slings. & yes, definitely more noticeable on the darker hulls. I'm watching to see if/when they start on mine, but again I do not get pulled yearly & I know the previous owner did not pull yearly either.
I keep my boat on a lift year round (so about 5 feet above the water
