Has anybody fitted a bow thruster to a Fiesta Vee 242
Hi!
I purchased my FV242 last year and would like to install a bow thruster.
Looked at a lot of picktures from other FV242s, but only found one with a bow thruster installed.
Does anybody have a BT in his 242? I would like to know which is the best position for the tunnel.
Thanks
Frank
Thanks
Frank
Frank / Fiesta Vee 242 2001 / 5.0 EFI / Germany
Cheers
Frank
Are you saying you already bought the thruster? If not, have you looked at external thrusters such as Sideshift?
https://rinkerboats.vanillacommunities.com/discussion/4465/where-to-place-a-bowthruster-on-fw-270-02/p1
thanks a lot for your comments.
I've bought one already and it arrived today.
The weather is still bad so I have to wait a bit and will find out where it fits best.
In the meantime I will go on with the other tasks (aligning the engine, connect engine, ...)
Cheers Frank
Did you already installed a bowthruster ?
I want to install it as well.
can you send Some pictures.
sorry for my late reply.
Yes, I installed the bowthruster in Mai. It was a Sidepower SE40S.
I used a 125mm diameter tunnel and placed it under the table stand area in the cabin.
Here are some picktures. Since I'm in a hurry, I just put some short comments...
My chief engineer cutting the hole to inspect the space...
Tested the right position with a model of the tunnel
drilled the holes from inside
borroed a special tool from the dealer, which is put through the holes on both sides.
big holes
Cutting the tunnel, leaving a few centimeters for the spoiler
getting rid of the gelcoat
Microfiber to glue the tunnel
tunnel is installed
view from inside
the microfiber for the glue
460gramm
and again the engineer
a couple of layers inside
testing if the thruster fits and cutting the holes in the tunnel
build the spoiler
cables with 70 square mm diameter because of >7m lenth
Cheers Frank
