Power steering pump
rasburyrasbury Member Posts: 8,709 ✭✭✭✭✭
Is the pump a standard gm pump for a 270 350 mpi? I think I toasted mine with the line that leaked the fluid...
Best Answers
  • rasburyrasbury Member Posts: 8,709 ✭✭✭✭✭
    Answer ✓
    @icoultha not sure I get the comment of " pump only" - doesn't it all kind of come together? I was shocked looking at oem new...what are they thinking? Any clue on figuring out the gm part number? You go into an auto parts store with a part and they look like a deer caught in the headlights.....
    Answer ✓
    I looked on both sites I normally look at ( including the one above) and do not see a part number for just the pump itself, only the asy. I need to get down there and get a better look and see what is going on....I don't think it is as simple as a hose unfortunately! Never seems to be that simple for me anyway...
    Answer ✓
    Thanks all.....My serial number is ow038097. This is all great info and I appreciate it. Admiral about had a cow as I left up the site showing the 700 pump....I need to get it pulled off and see where it is leaking. Heck it could be blowing up from the cap, I checked it and it seemed to be on there tight....resolving another issue and will get that pulled off/inspected this week. I was on the boat by myself....and low rpm it did not make and noise. Give it any gas and it starts to make noise- I don't think it was the belt....I had the hatch open and it looked like when I gave it the gas fluid was shooting out the bottom. The power steering itself is still working so I guess the pump is still functioning....?
    Answer ✓
    It does....I will get it pulled out and see what is going on....I'm sure missing out on some nice boating weather for sure....
    Answer ✓
      wow 212- that's awesome! I will get a picture of it..my motor is a 350 2006 MPI but I'm guessing there are not a lot of variables..I recall you replaced a motor....does it come turn key or would they not transfer stuff like that from old to new??
    I took a look but could not get any good pictures....it is starboard under the oil filter...both hoses connect at the bottom. I'm going to fill it and see if it leaks sitting there...hoses do not seem wet, face around the shaft seem wet. I will clean it up, take the belt off and spin it and see if it will show where it's leaking....
