No blower power 342
Doing my boat projects and hit the blower switch and no blowers. Worked fine 2-3 weeks ago. Power at switch. Breakers ok. No power at the blowers. Blowers work fine off direct battery power. Neither the helm or power panel switch turns them on. Both switches light up though. I've messed with nothing in the engine room since they last worked. Any thoughts? I checked the helm switch and it switches fine with a meter on it.
Len & Robyn 342 FV Freebird
Al - thanks for the comments. Both blower switches light up when turned 'on'. Both breakers good (not tripped and tested with a multimeter). No power at the pin connector at the blowers themselves. There is power at the swtich (helm). I'm jump the connectors to see if it works then, but not sure wich to jump, I think there are 6 wires at the connector at the switch.
Very odd as they both worked fine ~3 weeks ago. The only thing I have done with wires or even in the bilge was remove the engine room fire ext. to get it recertified. Would the fire ext switch be wired to cut the blowers off? There are 3 wires going to the fire ext, 2 black that are connected and the other wire (don't remeber the color off hand. Wierd they would BOTH go out at the same time.
Here's a thought that I think you were onto....... :-?
(LINK TO ANOTHER BLOWER DISCUSSION)
Just sayin' ....
Here's hoping that you'll plug that wiring for your recertified fire extinguisher back in and it'll all be good. It's the kind of system I wanted last year but just didn't get to. Heat sensitive release and/or manual release with a blower tie-in to shut down the blower that'd feed a fire new oxygen and to keep the fire suppressant from being exhausted......but I may be wrong. That happened once
(FIREBOY SUPPRESSION LINK)
Or SEAFIRE with FM200
An engine cutoff when fire suppression is tripped is an opt on a gasser but mandatory on a diesel from what I've read.
