F11 Topcoat
Dirtythirty
Member Posts: 393 ✭✭✭
Has anyone had any experience using F11 Topcoat on gelcoat ? My sides are painted, so I'm sure it will be fine for that area, but I was thinking about multiple applications down along my water line in hopes of keeping the scum line under control. Any thoughts ?
As far as the F11 goes, There is a video out there with a guy applying the product to a boat with blue gelcoat with heavy oxidation. From the angle the video is shot, it appears to gloss over the entire area. My thought is...(even if you don't wax it, at least buff it out first with polishing compound and then seal it with F11. That way, you know you are sealing a surface that already has a shine to it. If not, I would think that existing oxidation will just come through again.
@JoeStang : If you don't purchase some of your own, I'll post later in the season, how it holds up and how often I re-apply it
What I I'm NOT SO SURE of, is the claim that you apply it to heavily oxidized gelcoat and it magically brings back the deep luster the boat came with. I do think you need to apply it AFTER you buff out that gelcoat first.
Be nice to have a top coat of sorts though.
As far as boats.....not sure, I just use it topside. I doubt it will take out oxidation but I may be wrong.
