Parts for Cal A/C pump?
BellevilleMXZ
                    Member Posts: 732 ✭✭✭
                    Anyone know a place to buy parts for these? Specifically the o-ring that seals the plastic pump housing to the pump. Looks like this was put together wrong at some point and the o-ring is deformed. I have only been able to find the whole pump online. Can make one if needed, but would rather buy the right one.
when main control is turned on it sends power to the pump.
i fought with the hpf syndrome
i ran product through the ac and hoses to clean = probably good for the system
but still hpf = it looked like i had a pretty good flow
replaced pump and have been hot or cold ever since
if i remember right ... i cut the old wires and spliced the new 1 in.
the hardest parts is being able to see = you must take the old pump out and maybe the bracket = a must for me was a headlamp = mirror =stubby phillips,slot and plumbers tape=it was easier for me to lay in the aft cabin and work forward = fan is good idea if its warm ...good music ... some parts are plastic/i think ... one of the hoses goes through a little holder=i forgot to feed it through the 1st time
turn the water valve off = this should be 1st/top of list = some work by feel and dont be in a hurry = clean the strainer while in there = you will have to re prime.
maybe a hour-maybe two = but i am a un handy man
@reneechris14 = yes loosening the bracket is the way to go = 1st time for me
i didnt see it or the pump wouldn't fit = small jobs like this i try and do =i have no experience = fun and saves a few bucks
