HPF switch
Has anyone replaced theirs? I know where it is at, I have a new one, just have zero idea how to get it off.
2001 340 Fiesta Vee 20P Hill Marine and 2 new 6.2 Horizon motors. Whine Down
You may also want to try this website (which many years ago was very good and active, but may still have an answer already posted)
https://marine-ac.com/forum/?search=1&new=1&forum=all&value=hpf&type=1&include=1
https://www.amazon.com/Barnacle-Buster-Concentrated-Marine-Remover-1/dp/B014RD7XIW/ref=asc_df_B014RD7XIW/?tag=bingshoppinga-20&linkCode=df0&hvadid=%7Bcreative%7D&hvpos=%7Badposition%7D&hvnetw=o&hvrand=%7Brandom%7D&hvpone=&hvptwo=&hvqmt=e&hvdev=m&hvdvcmdl=%7Bdevicemodel%7D&hvlocint=&hvlocphy=&hvtargid=pla-4584413736088399&psc=1
I used it to flush my AC system and shocking what it flushed out.
In the bucket I used an old bilge pump with the output connected to the water line leading out of the AC water pump (bypassing the pump). Mixed the barnacle buster as instructed. Circulated the mix for ~1/2 hr.
You could run it thru the AC water pump but it needs gravity fed water to prime it. Too much to mess with.
After getting my system cleaned out I am going to do this annually.
BTW it will improve your AC / heat performance with the scale removed.
