Electric Hatch Problem
 PaulZ00
                    Member Posts: 19 ✭
PaulZ00
                    Member Posts: 19 ✭
                    Just got our 2003 Rinker 290. Pushed the button to open the electric hatch.. it almost seemed stuck at first. Then it kind of clunked but finally raised.
In doing so, however, it cracked the plastic bracket at the bottom of the hydronic arm.
My questions are:
1) Did I miss a step in opening the hatch?
2) Has anyone else had this problem?
3) How the heII do I open the hatch now. The hydronic arm won’t stay in place on the floor so it’s out of commission at the moment.
Thanks in advance for anyone’s input.
My questions are:
Post edited by raybo3 on
they always at the helm and cut power off to the lift switch.
from what I’m reading on here, that’s not normal.
The nylon brackets are made by a company called Lenco.
You don’t want that thing falling on you!
reason behind that is if you forget to pull the pin it will crack the hatch when closing
and show me how the canvas looks.
i will for sure stop by one of the days!
yes like people said in this thread said its aftermarket and probably designed for a lighter hatch like dual panel offshore
It was very obviously an after market product that had been replaced as there were three different types of screws used and the wiring was spliced.
Does anyone know a specific part number of the correct actuator that should be there?
I don’t want to take any chances with anyone getting hurt.
