Gear Lube Leak
It appears I have gear lube weeping from around the top vent screw on my alpha drive. I replaced the blue gasket and tightened firmly but still leaking. Anybody know of a quick fix(cheap) for this or am I buying more hardware? There may be some corrosion around the screw. Attached a few photos.
hole counter bore or vent screw is probably screwed up.
yellow just gives you more sealing surface vs blue
