Slow draining shower
cls10105cls10105 Member Posts: 389 ✭✭
The last 2 times the admiral has used the shower the water has drained really slow and caused the water to go to the toilet side...help please
cruising on 6. tw0s
  • BayrunnerBayrunner Member Posts: 177 ✭✭✭
    Mine did the same thing last season.  I have a bad float that went bad. Once I replace it, it drained fast. If that's not the problem make sure it not the pump or the filter is clogged.
    Bayrunner -- FV312 - Simple Pleasure
  • IanIan Member Posts: 3,024 ✭✭✭✭
    Can you hear the pump cycling? Either float as @Bayrunner suggested or you have a blockage to the pump. Have a look at the sump pump and see if is full or overflowing into the bilge
