Air conditioner showing wrong air temperature - problem with temperature sensor?
LaReaLaRea Member, Moderator Posts: 7,878 mod
My Marine Air Passport air conditioner has developed a fault with the temperature sensor.  The temperature displayed on the keypad hovers around 64-67 degrees no matter what the temperature is.  Anybody seen this before?
If keypad says 67 and I set the desired temp to 65, the AC comes on and works fine, so it's not a problem with the compressor/fan unit.  I tried unplugging/replugging the cable on the back of the keypad.  Any suggestions what to try next?
