What to use to fix corroded seat pedestal fasteners
We took the boat out today and had a seat malfunction. The co pilots seat pulled some of the bolts out that mount the pedestal to the floor. Obviously there are nuts under the floor that the bolts go through the seat pedestal, through the floor, and screw into and they corroded away. I would have to assume I’m not the first to have this issue and the issue being there there is no real access to get any sort of nut back under the floor, to bolt the seat pedestal back to. What’s the fix?
https://www.walmart.com/ip/Garelick-EEz-In-Stainless-Steel-1-4-20-Toggler-Bolt-Anchor/32741219
Can you cut a 6" hole in the floor and put an access plate in it's place?
Thanks to everyone for the suggestions.
Those toggle bolts are not really meant for that application let alone the vibration issues... you might get lucky!
While stainless steel is more corrosion resistant, it will still corrode.
