I can't seem to find any info on the hull construction of rinker 360s from the waterline up. Are the hulls solid fibreglass or solid fibreglass below the waterline and cored from the waterline up? Thank you.
As far as I know, wood core hull below the water line, with fibreglass layers, and gelcoat. Fairly strong hull relative to other brands. I don't think it would be cost effective to have a solid fibreglass hull.
I drilled a hole in mine for manserator and it was a good 3/8 thick, almost 1/2 inch I was impressed. solid fiberglass. about 12 inches above water line.
Hello I am also interested in knowing the below water line hull construction of my 2010 280, if anyone can pass this info on, I would be grateful. Thanks Bazza
Thanks Bazza
@JFDee intake for the head flush, my 2003 310 one for the head looks as you describe. The AC is very different.
you pee/poo and it escapes
hopefully not thru that hole!
I agree that it's the intake for the head water.
