342 battery switch and battery charger wiring - 4 questions
I suspect my battery charger on my 2002 342 has bit the dust. Had dead batteries. Replaced all the batteries (they all were old and tested bad) but they still all drained down. I think the cockpit fridge was causing the issue and the battery charger could not keep up.
Question 1: Not sure why or how my house batteries could take down my starting batteries. Any ideas?
I thought perhaps due to a bad battery isolator so I replaced that but when I pulled out the old one it tested fine (but for $120 and 30 min of my time I have that now ruled out).
So now I am looking to replace the charger (Intellipower PD 2040 - 40 amp unit) and bought a Pro Mariner Pro Nautic 1250 12 Volt 50 Amp 3 Bank Charger. a bit more power... 50 amp instead of 40... plus Amazon delivered to my door the same day I ordered it!! Everything I read says the chargers should be wired directly to each battery....not through a battery isolator as the current set up is. In doing my research I could not find any Rinker wiring diagrams for how the batteries are wired to the battery switch. The best I could find is the attached, which is an extract of an overall wiring diagram document that someone else posted but does not have what I am seeking. It shows that the battery charger is wired to the battery isolator and the isolator is wired to the battery switches.
Question 2: does anyone have a wiring diagram for how things are wired from the battery switch to the batteries?
Question 3: If the attached diagram is correct, am I correct in assuming that while the battery switches are turned off, none of the batteries will charge from the battery charger?
Question 4: Any advice of if I should wire my new charger like the old one or should I go directly to the batteries, bypassing the isolator?
My boat was wired as in the diagram: alternators going through the isolator, battery charger connected direct to the batteries.
The isolator has two inputs (for the two alternators). It has three outputs (for three battery banks). Your charger has three outputs, and you connect them to the isolator's three outputs. So, yes the charger outputs bypass the isolator, but the wires are attached to the isolator.
@reneechris14 - I am hoping after installing new batteries, new isolator and a new charger that all my problems go away.....there is not much else to check.....unless somehow the battery switches are wired incorrectly. I will keep you all posted once complete.
http://rinkerboats.vanillacommunities.com/discussion/10106/installation-notes-promariner-proisocharge-battery-isolator
So upon the discovery of the 8 AWG wiring this then meant I could not reuse these wires with the 50 amp charger I am installing (replacing my 40 amp Rinker installed charger) . Turns out that even if I stayed with a 40 amp charger, that too calls for 6 AWG wiring which makes me wonder about Rinker’s use of 8 AWG on my 2002. Maybe that is why the 2004 now uses 6 AWG.
So tonight I made all new cables with ring end connectors crimped on each end by yours truly. That was time consuming but easy. They will run directly from the charger to each of the three battery banks. So that is 3 wires plus a ground plus a chassis ground for a total of 5. Tomorrow I will finish the install and post pics. In the meantime here is a pic of the old unit and it’s replacement.
It has been a fun project. Learning a lot which is half the fun.
Rinker used #8 wire because the isolator is mounted next to the charger. It's a short wiring run, so #8 is big enough. Then you have bigger cables that run from the isolator to the batteries.
