Things that make you go Hmmm....
Willhound
Member Posts: 4,228 ✭✭✭✭✭
Just have to share this to show that stupidity has no bounds. I work in a small building supply and hardware store and a customer approached me today to cut him two feet of 3/8" soft copper tubing from a roll. When I asked if he was sure on the size (cut items can't be returned) he said "Yep, that will work for my battery cable". Thinking he meant to thread cable through it to protect it I pointed out that it was a little thin. "No, it's the right size to flatten the ends, bolt on a battery terminal and connect the batteries in my boat. It's only 99 cents a foot and the crooks at the marina supply want $3 a foot for cable".
I almost had a stroke...
I've seen garden hoses bought for household plumbing, wires and switches but no boxes to put them in, decks built without proper support, you name it. Bugs the crap out of me but after 10 years in the business I've learned to just shrug my shoulders and walk away for my own sanity. As the Blue Collar boys say " You can't fix stupid."
Was a short vid. My slipmate’s power cord. Tight and sliding up and down the piling with the waves. Brilliant.
he finally says after some volleying back and forth "look, if you just tell me what you're doing I may be able to help you out, or... may not- what's the harm?".... i took the bait and figured I'll be getting rid of this fella quick like....
"I'm plumbing in an 80 gallon auxiliary fuel cell in the bed of my truck with an additional airdog150 filter/pump for transferring precisely 1/4 tank of fuel, or 6 gallons, based on a timer switch which is controlled through an OE rocker switch and which will have a buzzer and an LED light, along with a digital fuel gauge i'll be able to see in my rear view mirror to monitor the fuel in the aux tank and determine how much was transferred mathematically by deducting the prior level to the level after completion of that particular timed function- however, i also need to plumb in two 12vdc normally closed solenoid valves on either side of the pump which will ensure no leakage- these have already been wired and have three legs- one is the transfer function which engages the timer board, the light, buzzer, and digital fuel gauge as well as both the solenoid valves, another function to allow one solenoid valve, no lights/gauge/buzzer and use a return line to the aux tank so i can 'polish' the fuel while i'm underway, and yet another leg that will be used in the rare event i actually want to transfer fuel to another vehicle or piece of equipment. I have all the wiring and electrical concerns covered, i'm just here for the fittings- which need to be NOT brass, but not polyethylene or whatever that translucent crap is either that can't endure temperature differential i'll be expecting from northern to southern climates. in addition to this, i have installed a eberspacher and i want it to drink from the aux tank as opposed to the main tank so i don't come out one cold morning and find the furnace drank all my fuel intended to get me to a diesel pumping station- it is regulated by a temperature switch and a thermostatic bypass which will run through two fluid to fluid coolers i'm using instead as heaters in cold environments, one fluid to fluid which will run engine coolant/antifreeze in the 'cooling' lanes which is heated by the eberspacher and will keep my engine warm no matter how cold it gets and i will use to push diesel through using the airdog150 on the second 'polishing' leg and returning to the aux tank, and then the second fluid to fluid cooler for the same purpose, but for engine oil.... my only concern is proper fittings and then how to NOT rely on thermal transfer between the main tank and aux tank for the warmed (read:no gelling) diesel"...
I SPIT that at him. I figured he'd say "good luck dude" and 180* out of there.... he didn't... instead, he asked an incredibly insightful question that stumped me butt cold. he was actually listening and actually followed what i'd incredulously dumped on him...
we ended up talking for about half an hour... as he turned to leave i told him "you better be looking for another job, man"... he twisted back and asked why... i told him, and i meant it, "you're too knowledgeable and personable for Lowes Home Improvement, which means you're gonna either get bored, or, somebody above you is going to be intimidated by you and sack you for some BS".
this Lowe's is half a mile away from my home. I go there all the time during different times and i've never seen him again.
i ain't the smartest person even on my street by a far stretch, but i ain't the dumbest either. i reckon it's the same with folks working retail, too. i also reckon i was clever enough to be right about that fella's fortune, too.
it was based on a single cam pushrod design. the cam bearing had a tiny motor adapted to it. the lobes of the cam were a compound angle which when slid backward engaged prior non-operational valves which activated not only entire 'dormant' cylinders, but additional valves as well- making the 16valve 8cylinder engine as much as a 32v, but with variable stages in between... coupled with fuel management and spark, and with the addition of boost in the form of a turbo, the engine went from a docile grocery getter to a vicious road track engine... or, flip a literal switch and it was a straight line drag engine... they were working on making it 'on demand' and which consisted of scripting for it's ECM and would eliminate the need for settings. the economy was absurd and the power remarkable depending on how you were using it.
never heard another things about it.
As for OPEC threatening over this: even with significant mpg improvements, the growing number of vehicles out runs it. Interesting fact: #1 user of diesel fuel in the world...the US Navy.
