Voltage Drop
Willhound
Member Posts: 4,224 ✭✭✭✭✭
Noticed last year while running that my voltage while under way was consistently reading about 12.8v on all 3 of my voltage guages. The stock dial, on my plotter and on the little temp/volt meter that plugs into my accessory socket. I was reading 13.4 to 13.8 at yge alternator but just to see I changed out the alternator and one house battery that had come with the boat. I had added a second house battery the year before. So one is a year old and the other 2 years old. Both pass a load test and readily charge.
As soon as I shut the engine down voltage drops to 12.4 and then quickly to 12.2 to 12.1 but will stay there all day. That's with fridge, stereo, plotter and VHF all running.
Should I be concerned? Maybe isolator?
I did pull the battery switch panel last year and checked connections and also clean and grease my battery terminal connections every spring.
Started at batteries and right away found that two of them I was able to get at least a couple of wrench turns on the connections. Just to be safe I also pulled out the battery switch panel and all those connections were good.
Now showing 14.2 to 14.4 from batteries.
So the moral of the story is start with the simple and most logical explanation. Even though I thought I had taken care when installing the batteries this spring I obviously either didn't tighten them enough, or at least should have checked them again after a few weeks.
