Overhead lighting ideas-no arch
So here’s another question. When overnighting on my “no arch” 270, I really could use overhead lighting in the cockpit. Has anyone come up with ideas?
https://www.harborfreight.com/ultra-bright-led-portable-worklightflashlight-64005.html
good idea. battery powered is obvious the easy way to go, but wired is more convenient in the end ... luvinlife just get a 12V LED and see if you can get a pick up somewhere off the courtesy light system.
you need to listen to your anal retentive inner voice ...
And I do listen, that’s what drives the Admiral crazy at times.
