Depth finder & GPS issue
Good day all,
So, I noticed my stock Fauria depth finder & Lowrance 520C act up at some point during the Michigan boating season. The GPS will not locate the boat, but will turn on, and the depth finder will turn on, but have a hard time finding the depth(flash various depths, not accurate). We just put the boat in on Friday, the 14th after a winter of sitting in a climate control warehouse, and of course, I turn them both on, and they are working fine. This issue seems like it could be connected, although I could be wrong. I am going to give the grounds and ground block a good look, as well as check the connections behind the gage panel. I am wondering if anyone else has experienced this?
The fario transducer is crap ... sorry, but they are unreliable. Your lowrance on the other hand should be more reliable ... although they say the transducer should be replaced every 5 years (they do eventually die).
In terms of the GPS ... one thing I found is to ensure you power down the unit before turning the main power off. It's not good to cut the power off the unit without a proper shut down. I had a standard horizon, and it would give me all kinds of problems until I powered it down properly, and after that NOT A SINGLE ISSUE.
The other thing I'm thinking is that I heard recently the GPS system had a glitch and it effected some devices ... not sure if it is chronic or a once off issue.
That's true, and actually you gave me an idea. The lowrance can run at 2 different frequencies ... one for shallow water (Wider cone) and one for deeper water. So if the frequency is toggled, he will be able to see if it is interference.
