1987 Rinker Fiesta Vee
I inherited a boat from my father in law. It had been in a barn for 6 years when I got it. At one point he was very mechanically inclined but his mind doesn’t work like it once did. The engine is a Mercruiser 260. When I got the boat the thermostat housing had been removed and was all laying around the engine bay. I got it all together and running, but I noticed coolant leaking. The port exhaust manifold started leaking coolant, I found a hose barb on the bottom of the manifold with nothing on it, and no hose laying around. There also appeared to be water (clear) coming out of a similar location on the starboard exhaust manifold. My guess is that the cooling system takes the engine coolant and runs it through an intercooler (not sure where it is located) and then the seawater pump sends the water from the outdrive to the exchanger. I don’t know where the heat exchanger is (should be located) and I am assuming it is a closed loop system. Any help would be appreciated.
