Shore Power on 2003 Fiesta Vee 270 Tripping GFCI
 ron1ma
                    Member Posts: 12 ✭
ron1ma
                    Member Posts: 12 ✭
            Hi All.
Searching to see if any Rinker owners have experienced this problem and what the possible cause turned out to be? I know it is most likely an open ground or something, but would be great if there was a common area to look for.
Thanks in advance...
Ron S.
Hi.
@ dude_Himself... The boat is in the water now but did the same thing when it was home on the trailer, so I swapped out the GFCI breaker with a standard one and then it worked just fine.
@ Stodge... Thanks will do. Like I said above it works with a normal breaker so I am assuming it is an open somewhere.
I have the same issue at my place, I have an old "dumb" plug on a lockout that I use just for the boat or to backfeed the house from the generator.
https://waggonerguide.com/elci-protected-shore-power/
@ dude_himself.... thanks i will check out these articles... much appreciated...
Ya they are getting pretty strict about that. I am going to use the articles Dude_Himself attached and am going to go through mine this weekend, so it finally works with GFCI.
Good luck with yours Stodge.
Any of you ever resolve your issues?
I don't think I'll give this much thought since it's only those one marina but I will look further into it. Lots of articles on it.
I seem to recall some hot water tanks had slight leakage to ground, enough to trip the GFCI breaker but not enough to cause harm.
Most marinas post signs about not swimming.
