Ground strap
I was in the bilge the other day and glanced at the ground strap/bar at the back of the bilge. It has 2 large posts, one at either end, then smaller posts in the middle. Lots of black wires going to it. One large black wire went to 1 large post then to (as far as I could tell) the port engine. But the other large post did not have anything. It made me wonder, should there be a similar large black wire from the starboard engine to the strap/bar?
The bus bar in the engine room just provides a convenient way to connect multiple small DC negative wires to a common return / negative point. The second large post on the bus bar is used to connect an extra bus bar if you run out of small posts.
I know cars use the actual chassis as a 12-, note there is no 120VAC on the vehicle. Note that boats do not tie the 12- to the engines or any part of the "chassis" on a boat. Not to confuse things even more, but there can also two more grounds on a boat. Lightning ground which is usually tied to mast on sailboats and go to a large plate on the keel. The other ground is an RF ground which is mainly used for keeping noise free radios.
RVs on the other hand, would have the chassis at 12-. Anyone know how the green AC ground is done on RVs? Is there a rod that should be put in the ground when you campout?
In theory the AC ground in an RV should track back through the source cable. You can put a stake in but then you'll introduce a ground loop and potentially trip a GFI if it's hih enough.
I wonder though for protection if they tie the chassis to the ground wire but somehow isolate the 12vdc -ve which is as you point out, for vehicles is normally the chassis also. Our RV buddy @Handymans342 should be able to tell us this.
