2002 342 FV Power Outlet Low Voltage
BlackWatch
Member Posts: 18 ✭
I'm having an issue with the 3 power outlets on the starboard side of the boat (wet bar, aft couch and fwd couch). I checked their voltage with a multi-meter and it's reading 89 volts. I'm plugged into shore power and the panel is reading fine with 120 volts.
The outlet for for the galley counter is working fine and reading (124 volts). From the schematic diagram I have, it looks like the other three outlets are all on the same circuit together and not connected to the galley outlet circuit.
Any thoughts on what to check? Thanks!
Checked the GFI's and all worked good. If the schematic I have is correct, the 3 outlets are on their own circuit, and there is no GFI on any of the 3 outlets.
Nothing plugged into them powers up due to the low voltage. What would cause the loss in voltage? Could it be corroded connections?
I figure a loose connection would be intermittent and not just cause a low, yet steady, voltage.
With respect to being a new problem...it's a new boat for me, so not sure on the history.
Shut off you 15A breaker and disconnect the wire (12/3) at the output - going to outlets
Take your meter and measure for 120v at INPUT side of 15A breaker,(use a known good ground or neutral)
If you have 120v, turn 15A breaker on and measure for 120v at OUTPUT side with NO wire connection
If you have 120v reconnect 12/3 OUTPUT wire and start disconnecting individual outlets.
This probably a PIA and easier said than done.
Of course, if there is no 120v at INPUT side of the 15A breaker, check your bus bar connections or swap the 15A breaker with another one on the panel. Since your other circuits have 120v and are working, the bus bar must have 120v.
Hope this helps, I've never seen this electrical panel, just going off the print.
Art
