270 Fiesta Vee
I have a land survey and sea trial tomorrow for this. it’s an ‘03.
2013 repower Merc 383 stroker and bravo 3
Epoxy coated bottom
genset elec. toilet
everything is in working order it has been replaced. $30k in receipts. comes with trailer that needs some TLC to be road worthy. Is there anything I should look for or be concerned with?
Thanks. looking forward to reading a lot here
Is there
Epoxy coated bottom
genset elec. toilet
Is there
270 is a great boat. Some of us have experienced water leaking into the cabin...particularly to the left of the kitchen sink by the storage cabinet. Check for any signs of water on the carpet in the area.
Can't really think of anything else a good surveyor would catch. 383 is a great motor to have.
Good Luck!
And that's after having the motor implode the first weekend I owned it.
The one thing I'm doing the moment I get settled in Florida (and having it behind my condo) is going to attack that problem full on.
moisture readings maxed out.
All 4 windows and hatch needed to be pulled and reset. hatch needed to be replaced.
corner near bath below window behind vinyl siding was soaked. windless pullpit was very loose. Had to walk away. Major leak somewhere
The bike pump also works well to pressure test the foot.
The bike pump plus a deflated basketball also works well to remove dents from inside fenders and door skins so i guess im saying everyone needs a bike pump!
If it looks good and passes the leak down dont give it a second thought. Just check each season.
If your fuel tank is over 7 or 8 yrs old chances are your fuel sending unit gauge seal is deteriorating anyway and needs a better viton or other rubber sealing gasket upgrade. I wouldn't be shocked at all if half or even more than half of of our high dollar non ethanol fuels test positive for low levels of ethanol and rubber materials from pre George Jr/Obama were not built to stand up to ethanol. Keep in mind most rubber is listed as ethanol resistant. Dony forget a good fuel resistant thread doping sealer on the sending unit bolts!!!! I can vouch that grey marine tex is pretty good at that, coating threads with wax before appying will ensure easy removal in the future. You just need a dab on each scew.
Most small leaks are around hoses/cuttings on the tank. A solution of dish soap and water in a squirt bottle or even kids squirt gun can help you find this.
It shouldn't be over whelming but if your boat has been covered/tarped or it's a 90 degree day with a full tank of gas it will be noticeable but not dangerous.
Only an inspection/leak down test of tank and lines can determine if you have a leak or its just boat smell. For 40 bucks you can buy a sniffer on ebay.
In newer boats there should be no smell.
Many boats that came with a plastic tank or had a plastic tank installed as additional fuel capacity or replacement of a leaky tank are stored with open hatches to lessen the odor.
If you have an aluminum or steel tank, all new lines, you're 100% sure all hose fittings are tight and still smell fuel, then you have an issue that needs immediate attention.
