Engine idles but dies when given throttle
Not the way I wanted to start my Independence Day vacation... I have a 2005 FV 342 with twin Volvo Penta 5.7s with fuel injection. My starboard engine runs fine but my port engine is giving me fits.
It starts and idles fine, but as soon as throttle is applied, is sputters, pops, and dies. It seems to be going lean. I replaced the fuel pump and filter, the injectors, and the spark plugs. I cleaned the distributer cap, and even swapped the computer with the starboard engine. Nothing worked, but it does seem to idle better. I even thought about water in the fuel but the starboard engine and generator run fine.
I'm at a loss about what it could be. Any ideas?
Could be there's enough water in the port filter to cause fuel starvation, but a bit less in the starboard filter.
knock sensors- will allow the engine to idle when there is a compelling pre detonation, but limits engine to 10% load.
air lock on the fuel line- enough fuel to run when the engine isn't demanding a lot of fuel, but can't keep up- which will also cause a knock, as well as/because of lean. go over those fuel lines again- get a towel and open the valve on the fuel rail either while it's idling, right after key on and it pressurizes, or right after killing it. get a fuel pressure gauge from the parts store- get a reading after key on (after it pressurizes), at idle, and watch it after key off to see how quickly pressure is lost.... hint: if it drops quickly, there is a leak somewhere allowing air in OR it has air trapped. you should have equal fuel pressure no matter the load or RPM- the engine's PCM demands that in order to trim fuel properly. My guess is, you'll likely just need to depress the valve stem on the rail until fuel flows. akin to this, and wondering what prompted you to install new pumps/filters- is it possible the rail is fouled with debris?
and a bonus/other suspect: fuel pressure regulator.
