370 ex- engine sensors keeping going off
we just purchased a new (40) 370ex. We are in fresh water but dealer had in salt for a few months and the first 40 hours. Amazing boat but the water pressure sensors keep alarming on computer when we go above 3k rpm then it forces us to go below that. We replaced them and still doing that or saying engine is over heating. Thought it might be impellers but those look great. Everything is on the computer so we are not sure if it’s computer or engines. We are on a lake with no service so have to wait on mechanic. Anyone have any ideas. The guys on our dock are very engine smart but this new beast has them stumped. Engines are 8.2 l b3 DTS with joystick .
Best Answer
Michael T
Member Posts: 7,227 ✭✭✭✭✭
@joannwinters - I had the same bloody problem with my 2014 EC 360 with 502s and Axius. It nearly drove me nuts until we solved it. Water pumps were replaced etc. There were two problems. One was "ghost codes" it took a while for a Mercruiser 5 star master tech to figure it out but the computers were retaining "ghost code faults" even when the problem was solved and the error code supposedly erased using a Mercruiser provided lap top with proprietory Mercruiser programming. These "ghost codes" would trigger false shut downs and prompt rev limits which were a serious problem if trying to dock in a wind and find your rpm was reduced (falsely) to 500 rpm. I was fuming mad and tore a strip off Mercruiser. The Provincial (State) Mercruiser factory representative had to have a new master program installed (from Mercury) on his personal lap top to fix this. Second, I was told that they were having sensor failures - particularly of the water pressure and water temperature sensors of up to 90%. I called the distributor and he said that was true. I was told it was still cheaper to have them made off shore in some crappy little factory somewhere. I asked what about the labor cost and customer inconvenience not to mention the safety factor......a big reason for bringing manufacturing back to the U.S.A.
Clean strainers?
Clean heat exchangers?
My be dealer just had it sitting still for while and biult up some growth?
High pressure means a blockage downstream from the pump - most likely in the heat exchanger, which is easily checked and flushed. Low pressure means a faulty pump/impeller or a blockage before the pump. Any of those conditions can happen at any time regardless of engine hours.
Scoring of the pump housing could happen in a few minutes if you run the engines while grounded in sand or coarse mud.
