370 ex- engine sensors keeping going off
we just purchased a new (40) 370ex. We are in fresh water but dealer had in salt for a few months and the first 40 hours. Amazing boat but the water pressure sensors keep alarming on computer when we go above 3k rpm then it forces us to go below that. We replaced them and still doing that or saying engine is over heating. Thought it might be impellers but those look great. Everything is on the computer so we are not sure if it’s computer or engines. We are on a lake with no service so have to wait on mechanic.  Anyone have any ideas. The guys on our dock are very engine smart but this new beast has them stumped. Engines are 8.2 l b3 DTS with joystick .
Best Answer
  • aero3113aero3113 Member Posts: 9,648 ✭✭✭✭✭
    You say the impellers look great, take a close look at the housing and see if there is any scoring. If there is, the impellers won’t be able to provide enough water pressure.
  • joannwintersjoannwinters Member Posts: 26
    Would salt water cause the scoring
    It would be more from sand/silt.
  • earl1z19earl1z19 Member Posts: 367 ✭✭✭
    What do your temp gauges tell you? Is it actually overheating? Is it one or both motors? I thought all of the 8.2's were closed loop cooling?
  • IanIan Member Posts: 3,018 ✭✭✭✭
    Scoring after 40 hours? Running through gravel?
    Clean pick ups?
    Clean strainers?
    Clean heat exchangers?
    My be dealer just had it sitting still for while and biult up some growth?
    like barnacles or mussels in the cooling water plumbing?
  • LaReaLaRea Member, Moderator Posts: 7,999 mod
    The water pressure is low, or high?
    High pressure means a blockage downstream from the pump - most likely in the heat exchanger, which is easily checked and flushed.  Low pressure means a faulty pump/impeller or a blockage before the pump. Any of those conditions can happen at any time regardless of engine hours.
    Scoring of the pump housing could happen in a few minutes if you run the engines while grounded in sand or coarse mud.
  • GMSLITHOGMSLITHO Member Posts: 1,602 ✭✭✭✭
    Yep make it here
    Thank you all for the info. Micheal T- we replaced water pressure sensors twice now and they are not working fine. Both impellers are great as well as housing . The port side engine is still throwing alarm . Both engine read 170 while just running 1500rpm. Computer says port side overheating and shuts us down . Everyone is stumped but after reading your post I am thinking it may be computer . We are seeing a merc mechanic today . We were able to run 45mph for awhile a few days ago before the alarm sounded . Now it’s going off while idling. Glad it’s under warranty but need to find someone who knows how to fix it . We live in area that doesn’t have a lot of bigger newer boats
    @joannwinters - unfortunately this sounds all too familiar - good luck! MT
    Update - water pressure sensors replaced, impellers look great, water pump fine, software updated.  We can take off and run 45 mph and she runs perfect until we throttle down then water pressure alarm goes off.  The SAME thing happens if we are going 10 mph or less - then trottle down and the same alarm.  We cleaned all the intake hoses - did find some debris from being in ocean and hoped it would work but not!  Replacing poppet value and gasket this week as the next step.  We are pretty much positive its a water flow issue - anyone have suggestions?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,861 mod
    Thank you for the update.  To me, it still sounds like it could be something with the water pump.  They can look ok, but not be ok.
    Thanks we will give that a try.
