Hatch lift noise and fix...sort of
Aqua_Aura
Member Posts: 2,690 ✭✭✭✭✭
I have always had the grinding noise I hear so many people complain about and I assumed it was the gears in the drive portion of the lift so I did grease the zerk fitting with no improvement. The other day after boating the hatch would not open but I could hear the motor running when I pressed the switch. I opened the hatch manually by pulling the pin and brought the lift home and tore it down. Apparently it went so far to the down side it got jammed and was stuck down but the jack screw is allowed to spin freely within the ram at full retraction and extension to protect the gears and motor. I took it completely apart cleaned everything and greased the jack screw very well. If you look in the photo on the right side of the jack screw at the end that is the free spin mechanism that had jammed so I cleaned that very well and re greased it. Its all back together and painted and works well however it still makes that slight grinding noise. I think to fully fix that you would have to basically polish the screw and the mechanism it goes into which I am not gonna do, I am just happy to know its clean moving freely and not grinding the gears.
Hopefully this post will shed some light for boaters since this seems to be common. I know I was a little alarmed when hearing the grinding noise. I would hate for someone to pay money for a new one for really no reason and to probably have the same issue.
Yes, try it on a 400! It took 6 of us on mine to do it, along with some creative thinking.
I'm wondering. It looks like I can unscrew the outer tube (as AA mentioned) while everything is still attached and holding the hatch up? I'd like to get grease in better spots (like the jack screw), but really have no easy way to hold my hatch up without it there.
No handle on the 400s.
I have same lift on my Four Winns, common issue with the Grinding noise after several years of use.
Thanks for the pics - was wondering how to tear it down
what type grease did you use in worm gear?
I will probably remove mine again and polish the long worm gear and add in more grease to the tube since it still does make some noise.
When I removed it I cut the wires in the boat since there was no connection and when I out it back in I used really good heat shrink/glue connectors that were male/female so I can unplug in the future. Motor has 1 male and 1 female so I don't accidentally connect it backwards.
did you find a manual or parts list anywhere?
I have unscrewed the Outer tube but the jackscrew is bound up inside the tube.
should I be able to pull the tube completely off the jackscrew?
do I need to pull off the motor to release the jackscrew?
Did you pull and replace the seal in the top of the tube?
Or did you just clean and Lube the old Seal?
The top seal I left in place and didn't replace it, no need to we just cleaned it.
In your cases you could just leave the motor on unless you want to clean the gears.
ITS LOUDER THAN WHEN I STARTED :'(
I ordered an actuator from Progressive Automations that is waterproof and meant for harsh applications like marine use. I don't think it is ignition protected however since it is waterproof and able to operate fully submerged I would assume by default it is basically ignition protected. It was only $180 compared to $500 for Eddie Marine or Hardin Marine.
If anyone have other suggestions for replacements I am open to comments 😊
