How Much is TOO Much Play Bravo 3 (side to side)
picturethis
Member Posts: 103 ✭✭
I just noticed that I have 3 Inches of play in my B3 27' captiva. The season is almost over and getting it into the shop is 2 weeks out . My question is the boat safe to use?? Whats the worst case here?
I am a new boater with my first boat, thats why some of my questions seem dumb
If you look at the top of the ring on the inside you can see the pin. Move the drive and watch the pin they should move together if not thats is the play in the pin. Also lift up on the drive and see if there is play that way.
JR marine solution is to drill to gain access to the steering arm so the motor does not have to cone out.
Other options is to pull the motor and change the hole transom assembly ($2000~) with this option bellows trim cylinders are all new.
My ring didn't need to be replaced. If everything is tight, it shouldn't wear.
