Do I have a battery charger problem?
Spyderweb
Member Posts: 947 ✭✭✭
I have an Intelli-Power PD2130 charger on my 2008 330, likely original. This is 2nd season with boat, never noticed a problem. There are 3 outputs, wired to 2 starter batteries and house (2 deep cycle). I try and not run my house below 12.2 volts, as measured on the volt meter at the electrical panel. Typically, that's what is measured at the end of a day on the water. We go back to the dock for evening and it gets recharged overnight. House batteries are on 2nd year, and typically read around 12.5 at beginning of day.
Yesterday, towards the end of the day out on the water, I fired up the generator just to run it for its weekly 20 minutes as has been suggested on this forum. Turned on breakers for water heater, fridge, ice maker, microwave, and battery charger to put on a load. Checked volt meter and volts had only risen to 12.3 (from 12.2). According to charger instructions boost power is 14.4, normal power is 13.9, and storage power is 13.3. And those seem typical for what I've seen in the past. Seems like with only 12.2 in the batteries, I should be getting 14.4 or 13.9.
Back at dock, hooked up to shore power, (only a 15 minute boat ride) I turned on charger and it went to 13.3. So better than on the water, but again I would expect 14.4 or 13.9, not a storage voltage.
Next morning, I went in to ER to check readout at charger, and it was giving me 13.3 volts (same as on gauge in cabin) for all 3 outlets and 0.6 amps. After being on all night, that's what I might expect. While I was watching the meter on the charger, it suddenly jumped up to 14.4 volt. I had my wife check, and the meter in cabin also had jumped up to 14.4. but within 30 seconds, it went back to 13.3. According to the manual, there is an "equalize mode" where every 21 hours, the voltage will jump to 14.4 and last for 15 minutes. So this may have been the mode it jumped to (about 14 hours after the charger was turned on the night before), but it only lasted 30 seconds.
Are these typical signs charger is starting to go, or is something else going on?
Paul
Paul
Just to be sure, your charger runs off of both the genset and shore power?
The charger shouldn't care if it's 110 shore power or genset. Are you positive the charger was on while the genset was running?
What size genset are you running? Being that it works on shore power i want to know whats with the charger when the generator is running. Maybe try turning off some other breakers? Also did you run the genset the 15 min trip back to charge the house batteries? Maybe they were just that worn down. Have you charged both batteries then done individual load tests on them?
That said - I have the same charger and occasionally it must overheat or something because it doesn't always charge to full right out the gate. Sometimes it needs to sit a while before the batteries start bulk charging.
Charger was not on during trip to dock. So house bank would still be pretty low and I would expect with charger on at shore, volts should be 14.4 or 13.9. I have not load tested batteries. But at just 2 years old, and being consistent all season (down to 12.2 at end of day on water), I don't suspect the problem lies with batteries.
I'm thinking towards end of day, house batteries are low, reading 12.2 (although may be a little better than that because fridge and stereo are on), but certainly not high enough that the charger would think it was full and thus stop.
In my case, it seems that the charger is successfully maintaining the starting batteries, but I don't think the house batteries are charging. During the winter, all batteries were showing "red lights" in the AC Delco battery healthy indicator. Now only the house batteries are red, the starting batteries are green.
Boat has not been out on the water yet so I can't verify if the alternators are charging the house batteries or not. I also haven't put a voltmeter on the batteries.
Isolator perhaps?
My 1st thought on your case, do you know age of the house batteries? When I got my boat, the 2 house batteries were bad and wouldn't take a charge. It was a battery problem, not charger problem.
I will put my deWalt charger on them and see if I can get a green light. If not, I'll pull them and have them load tested I guess.
@YYZRC I know load testing is the way to go, but I've had some bad experiences with load testing. When buying boat, survey showed the 2 house batteries were bad. Bought the boat. Went to replace in spring, but broker (marina owner who stored/winterized boat) had removed the batteries over winter, then reinstalled in spring. Problem was, all 3 batteries on that side were identical deep cell batteries, so I had no way of knowing which were the 2 bad ones. He sent out his mechanic with a load tester and I watched him test all 3. He showed only 1 was bad. I replaced that one, and very shortly after, learned the other was bad too.
