Installation of water heater
Have 2004 Rinker Viesta Vee 312 and need to know the proper way to take out the old and put in new, as the heat exchanger didn't get winterized properly.
Best Answer
Dream_Inn Member, Moderator Posts: 7,749 mod
I believe your water heater is in the same place as mine was on my 2002 310. It is located behind the storage space on the stbd side of the aft cabin. Remove power and fresh water pressure first. You need to remove the small circle access (after getting into the storage space behind the cushion), then remove the screws holding the aft white panel/wood. From there, you'll need drain the water heater tank (using plastic drain and opening pressure relief valve - note, it will go into mid cabin bilge). Then remove both fresh water lines and both lines that come/go to the motor. There are 4 bolts holding the heater down, 2 in front and 2 in aft. The 2 in the aft are extremely difficult and you will need to be over top of the heater with the appropriate length screwdriver (longer than the height of the heater). After that, it should come out.
Installation is just basically the opposite. While you are in there, you should add the bypass which will allow for easier winterization.
From your comment about the exchanger, I'm assuming you have "raw" water going thru your water heater. If your motors are fresh water cooled, then you need to be concerned about antifreeze in the lines going to/from the motor.
Oh, & welcome to the forum! The 312 is a great boat! Where do you use your boat?
The two screws on the aft side of the heater is absolutely the worst! It was probably the hardest thing I had ever done on that boat is removing the stbd aft screw on that heater. I didn't put that one back in on install.
Oh, and make sure it's full of water before you turn it back on. (you can keep the element out of the old one as a spare)
