Fridge
the fridge temperature knob is stuck , the fridge works well but can't move knob to change the temp.Do you have any suggestions ?
  • WillhoundWillhound Member Posts: 4,230 ✭✭✭✭✭
    They stick from not being turned. The knob should pull off. Use some penetrating oil around the stem and carefully try to turn back and forth with pliers.
  • Ilovemyrinker2Ilovemyrinker2 Member Posts: 1
    Our  Dominic upper deck fridge  was working just fine before storage. Now  it does not work at all.  No lights power etc. Power plug in switch is working. The knob you refer to inside is stuck as well. Does that knob turn the fridge off and on by chance?  If we unstick it maybe the fridge would work?? We really don't want to buy new fridge if this can be fixed .Thanks.
    Do you have a green light on the thermostat housing (next to the knob)?
